Smarter Azure Monitoring in 2026
Most Azure monitoring tools leave you chasing symptoms—latency here, a cost spike there—without the full picture. This series gives you practical guidance to rebuild your monitoring strategy around what matters: the right metrics, service-level insights, and full performance-cost correlation. It’s your blueprint for modern Azure operations.
1. Azure Monitoring vs. Cloud Observability
Monitoring shows when something breaks. Observability shows why. Learn why CloudOps teams need observability to stay ahead​.
Understand the difference
2. 5 Challenges of Monitoring Azure at Scale
As Azure environments grow, so do monitoring gaps. See why scaling often exposes visibility, alerting, and cost control issues​.
See the top challenges
3. Azure Metrics Beyond Uptime
Tracking uptime isn’t enough. Discover which Azure metrics matter most for performance, resilience, and real-world user experience​.
Find the right metrics
4. Azure Metrics That Cut Cloud Costs
Not all Azure metrics impact your bottom line. Find out which ones help spot waste, optimize spend, and avoid surprise bills​.
Reduce your cloud costs
5. Azure Metrics That Protect Uptime and Security
Some Azure metrics do more than track performance. They help catch threats early and protect critical services​.
Protect uptime & security
6. Correlating Performance, Cost, and Security in Azure
Explore how correlating Azure metrics across performance, cost, and security unlocks deeper insights.
Correlate your data smarter
7. 4 Azure Monitoring Pitfalls (and How to Fix Them)
Outdated monitoring habits create blind spots, alert noise, and wasted resources. See common mistakes and how to fix them fast​.
Avoid common pitfalls
8. Consolidating Azure and Multi-Cloud Monitoring
Too many monitoring tools create silos and noise. Explore why CloudOps teams are moving to unified, cross-cloud visibility​.
Unify your monitoring
9. Optimizing Azure Costs Without Losing Visibility
Cutting cloud costs shouldn’t mean flying blind. Learn how to save on Azure spend without sacrificing performance insights​.
Optimize without blind spots
10. Why Metrics Alone Aren’t Enough
Metrics show symptoms, not causes. See why adding events, logs, and traces is critical for faster root cause analysis​.
Go beyond metrics
11. Solving Azure Monitoring Gaps with LM Envision
Azure Monitor catches the basics. LM Envision fills the gaps with deeper correlation, smarter alerting, and full multi-cloud visibility​.
Close your visibility gaps
12. 8 Azure Monitoring Best Practices with LM Envision
From smarter alerting to cloud cost control, these best practices help CloudOps teams get more from Azure and LM Envision​.
Adopt best practices
13. Success with LM Envision
Read about real world wins LogicMonitor customers have experienced with monitoring their Azure resources through LM Envision.
Filter your results Showing 8 of 46
Cloud Usage Cost Metrics: What to Track and Why
Blog Cloud
July 3, 2026
14 min read
Learn which cloud cost metrics to track, from spend and utilization to unit economics, and how to turn insights into accountable actions and measurable savings.
July 3, 2026
14 min read
Autonomous IT Starts Now: Meet LogicMonitor at AWS Summit New York
Blog Cloud
June 4, 2026
4 min read
See how LogicMonitor brings Autonomous IT to AWS with Edwin AI, Catchpoint, and unified visibility across hybrid systems.
June 4, 2026
4 min read
Take Control of Cloud Costs with Proactive Budget Alerts
Blog Cloud
April 23, 2026
5 min read
Forecast-based budget alerts help cloud teams catch cost drift early, improve FinOps visibility, and prevent overruns before they hit month-end.
April 23, 2026
5 min read
Cost Optimization in Action: How We Cut Amazon SQS Costs by 87%
Blog Cloud
March 17, 2026
4 min read
An inside look at how LogicMonitor reduced AWS SQS spend by 87% by embedding cost data directly into observability workflows, aligning performance, reliability, and financial efficiency.
March 17, 2026
4 min read
Cost Optimization for AI Workloads: From Visibility to Control
Blog Cloud
February 20, 2026
6 min read
AI workloads introduce unpredictable cloud spend driven by GPU utilization, token-based pricing, and distributed infrastructure. Discover the hidden cost drivers behind AI initiatives and what it takes to gain unified visibility, forecast accurately, and establish sustainable cost control across cloud environments.
February 20, 2026
6 min read
How LogicMonitor Delivers AI Cost Optimization
Blog Cloud
February 20, 2026
5 min read
Unified observability brings together AI telemetry, infrastructure performance, and cloud billing data to expose what’s driving spend. See how integrated dashboards, forecasting, and data-driven recommendations enable continuous, operationalized cost control for AI workloads.
February 20, 2026
5 min read
Top 6 Cloud Monitoring Challenges in Hybrid & Multi-Cloud Environments
Blog Cloud
February 18, 2026
12 min read
Scale and flexibility meet blind spots. These six cloud-monitoring challenges explain why visibility, triage, and trust fail during incidents.
February 18, 2026
12 min read
See Your Cloud Costs Clearly and Optimize Them Confidently
Product Brief Cloud
November 25, 2025
0 min read
Cloud cost clarity and control are critical as environments grow more complex. LogicMonitor’s Cost Optimization empowers IT and Cloud Ops teams to manage multi-cloud spend efficiently, validate recommendations, and prevent budget surprises.
November 25, 2025
0 min read
Stop guessing. Start seeing.
Get full observability across Azure, hybrid, and multi-cloud with LM Envision.
