What is FluentD, and how does it work with Kubernetes?
Known for its built-in reliability and cross-platform compatibility, FluentD addresses one of the biggest challenges in big data collection—the lack of standardization between collection sources.
With a decentralized ecosystem, FluentD offers a way to seamlessly collect logs from applications on Kubernetes. The free open-source data collector is positioned to support big data as well as unstructured and semi-structured data sets for better usage, understanding, and analysis of your log data.
This post defines FluentD, shows examples of its use in business, and provides tips on how to get started with FluentD in Kubernetes.
A cross-platform software project developed for Treasure Data, FluentD, helps solve the challenge of big data log collection. Licensed under Apache License v2.0 and written in Ruby, the program bridges the gap between data collection sources by supporting both Linux and Windows.
FluentD tracks Windows event logs with the latest versions and helps unify the collection and consumption of data, providing a better understanding of how it can be used effectively for business. After logs are read and matched with a tail input plug-in and then sent to Elasticsearch, Cloudwatch, or S3, FluentD can collect, parse, and distribute the log files.
With a seamless sync between Kubernetes, FluentD promotes better monitoring and managing of services and infrastructure. Kubernetes allows you to fine-tune your performance as you look for faults.
Companies such as Amazon Web Services, Change.org, CyberAgent, DeNA, Drecom, GREE, and GungHo use FluentD for its easy installation and customization with a plugin repository for most use cases. The program offers visualization of metrics, log monitoring, and log collection. Furthermore, as an open-source software project, its community of users is dedicated to making continuous improvements.
“FluentD bridges the gap between data collection sources, enabling seamless integration and analysis of logs.”
FluentD in Kubernetes helps collect log data from data sources using components that compile data from Kubernetes (or another source) to transform logs and then redirect data to give an appropriate data output result. In turn, data output plug-ins help collect and repurpose the data so that log data can be better analyzed and understood.
FluentD is designed to be a flexible and light solution with hundreds of plug-in options to support outputs and sources. FluentD in Kubernetes offers a unifying layer between log types. As plug-ins are built and used with FluentD, more ways to analyze application logs, clickstreams, and event logs become available.
You can break FluentD down into several components.
One of FluentD’s greatest strengths is its extensibility. It has plugins available that allow integrations with most third-party applications (AWS, Azure, Elasticsearch, MySQL, and others). These allow FluentD to collect data, process it in the FluentD engine, and output it to the storage environment of your choice.
There are many types of plugins available to use:
FluentD’s buffering mechanism is what allows it to efficiently process large amounts of log data quickly and get data where it needs to go. It needs effective buffering to ensure all data gets processed and nothing gets lost in translation.
It does this with effective processing usage using chunks, memory storage, backpressure mitigation, and retry mechanisms.
FluentD uses a hierarchical file structure to handle system configuration. It uses configuration files that contain directives for input sources, output sources, matching, system directives, and routing.
One of FluentD’s strengths is its dynamic run configuration—you don’t need to reboot the entire system to enforce changes. This allows for easier configuration and testing of new environments.
FluentD also allows for complex routing based on your logs and unique situations. It offers tags and labels in configuration files to help direct output to the right source.
Environments using FluentD can use a lot of resources—especially when processing large amounts of data or working in resource-constrained environments.
FluentD offers a few solutions to help these situations:
FluentD includes a unified logging layer, making logs accessible and usable as they are generated—allowing them to quickly view logs on monitoring platforms like LogicMonitor. On top of that, data sources can be decoupled to iterate data faster, creating avenues for more effective and efficient uses. Here are the top reasons why FluentD in Kubernetes is the best open-source software for data collection:
“Set up FluentD in 10 minutes and take advantage of over 500 plug-ins for your specific use-case scenarios.”
FluentD is rated one of the easiest to maintain and install data collection tools compared to other choices like Scribe and Flume. Regardless of the tool, the goal is to get the fastest and most streamlined data-collecting experience. These best practices cover FluentD’s quick setup, which leads to quick optimization of logs and processing.
FluentD is designed to be simple and easy to use, but adding extra computations to the configuration could make the system less robust, as it may struggle to maintain and read data consistently. It’s typically well-advised to streamline data as much as possible throughout data processing, and FluentD is no different. While FluentD is flexible enough to handle even demanding data requirements, maintaining a simple data-collecting system is best.
If you find that your CPU is overloading, try a multi-process. Multi-process input plug-ins allow the spin-off of multiple processes with additional configuration requirements. While multiple child processes take time to set up, they help prevent CPU overload and bottlenecks of incoming FluentD records.
Ruby GC parameters tune performance and configure parameters. RUBY_GC_HEAP_OLDOBJECT_LIMIT_FACTOR lowers values and improves memory usage (default is 2.0).
FluentD is deployed in Kubernetes as a DaemonSet so that each node has one pod. As a result, logs are collected from K8s clusters and can be read from the appropriate directories created for Kubernetes. In addition, logs can be scrapped, converted to structured JSON data, and pushed to Elasticsearch via the tail input plug-in.
FluentD allows the analysis of a myriad of logs regardless of the organization. The program’s flexibility and seamless cross-platform compatibility offer superb communication of real-time data analysis without the danger of integrating bad data or experiencing the torture of a slowdown.
LogicMonitor is determined to provide effective solutions for teams using FluentD for logging.
LogicMonitor’s Envision platform offers a comprehensive hybrid observability solution for organizations that need help monitoring hybrid environments. Its integration with FluentD will allow your organization to unlock FluentD’s potential and take advantage of everything it can offer.
Contact LogicMonitor to learn more about our Log Analysis today!
FluentD is an open-source tool for centralized log collection. It integrates easily with Kubernetes and helps organize raw log data into readable formats that can be filtered, searched, and sent to tools like Elasticsearch for analysis.
Deployed as a DaemonSet, FluentD collects logs from each node in a Kubernetes cluster. It then parses, transforms, and forwards them to systems like Elasticsearch or S3 using configurable plugins.
FluentD supports structured, semi-structured, and unstructured data formats. It uses parsers and filters to convert and enrich logs. This helps to improve data processing and analysis.
It’s highly extensible, with over 500 plugins for input, output, filtering, and buffering. It’s also platform-agnostic, lightweight, and backed by an active open-source community.
FluentD stores data in chunks (usually 2MB) using memory or disk. It includes retry mechanisms and backpressure control so that data processing remains reliable even under high loads.
Plugins help FluentD support custom log sources (HTTP, APIs), destinations (SQL, S3), and transformations. You can use input/output flows for nearly any log collection setup.
LogicMonitor integrates with FluentD to enhance hybrid observability. It provides a centralized view of logs and metrics, which helps teams monitor Kubernetes and other cloud-native systems more effectively.
