Elastic Beanstalk vs. ECS vs. Fargate: Which AWS Service Fits Best?
This guide discusses each of these technologies. It will also answer the question: “What are the differences between Elastic Beanstalk, EKS, ECS, EC2, Lambda, and Fargate?”
Beanstalk deploys fast, ECS gives full orchestration control, and Fargate runs containers without servers.
Elastic Beanstalk is best for fast deployments with minimal infrastructure management
Fargate lets you run containers without managing servers, making it a good fit for teams comfortable with ECS or EKS
ECS gives you more control over container orchestration and is ideal for complex, multi-service apps
Choose the option that matches your team’s infrastructure control needs and the time it can dedicate to managing it.
AWS offers multiple ways to run applications because different workloads require different levels of infrastructure control, scaling behavior, and operational responsibility.
The deployment model you choose affects:
How much infrastructure your organization manages
How scaling behaves under load
How much architectural control you retain
How your CI/CD pipeline integrates
How predictable your costs are at scale
Whether your system supports portability or vendor lock-in
How much operational overhead your organization absorbs
Therefore, when it comes to Elastic Beanstalk vs. ECS vs Fargate, there is no universally “better” option. There is only the right fit for a specific workload and your organization’s maturity level.
Common Compute Models for Running Applications on AWS
AWS provides several services that help you run applications with different levels of infrastructure control. The model you choose affects how your application is deployed, scaled, and maintained in production.
Here are the primary ways you can deploy applications on AWS:
Amazon EC2 (Infrastructure-as-a-Service): Virtual machines with full OS-level control, manual scaling, and custom networking (VPC, Security Groups, EBS, AMIs).
Elastic Beanstalk (Managed PaaS on EC2): Application deployment abstraction over EC2, Auto Scaling Groups, and Elastic Load Balancing.
Amazon ECS on EC2 (Container Orchestration + Managed Instances): Docker-based workloads with task definitions, service discovery, IAM roles, and EC2 capacity management.
Amazon ECS on Fargate (Serverless Containers): Container execution without EC2 provisioning; compute capacity managed by AWS.
Amazon EKS (Managed Kubernetes Control Plane): Kubernetes-native orchestration with cluster autoscaling, CRDs, and ecosystem tooling.
AWS Lambda (Event-Driven Serverless Functions): Stateless compute triggered by S3, API Gateway, EventBridge, DynamoDB Streams, etc.
Hybrid Models (ECS + EC2 + Fargate Combined): Mixed capacity strategies where baseline workloads run on EC2 and burst traffic runs on Fargate.
Quick Comparison: Elastic Beanstalk vs. ECS vs. Fargate
Not sure which AWS compute option is best for your needs? Here’s a quick side-by-side look at Elastic Beanstalk vs. ECS vs. Fargate to understandwhat you get and what you’ll need to manage with each service:
Feature
Elastic Beanstalk
ECS
Fargate
Service Type
Platform-as-a-Service (PaaS)
Container orchestration service
Serverless container compute engine
Primary Purpose
Deploy applications without managing infrastructure directly
Orchestrate and manage containerized applications
Run containers without managing EC2 instances
Level of Infrastructure Control
Low–medium
High
Medium
You Manage Servers?
No (indirectly via config)
Yes
No
Ease of Setup
Easiest (upload and go)
Moderate (define clusters, tasks, IAM, etc.)
Easier than ECS, but still requires task definitions
Scaling Method
Managed via Elastic Beanstalk Auto Scaling
Configurable auto/manual scaling
Auto scaling per task
Best For
Dev teams who want to focus on code, not infra
Teams needing orchestration + control
Teams needing fast, scalable deployments with less ops
What is Elastic Beanstalk?
If you want to deploy code fast without worrying about infrastructure details, Elastic Beanstalk is the simplest path on AWS.
Just upload your code and configuration files; Elastic Beanstalk handles the rest. It provisions servers, sets up environments, manages networking, deploys your app, and scales it based on traffic. You get a working web app in minutes instead of hours.
Beanstalk supports common runtimes and frameworks like Java, .NET, Node.js, Python, Go, Ruby, PHP, and Docker, and runs on familiar servers like Apache, Nginx, Passenger, and IIS.
Elastic Beanstalk Architecture
When you deploy to Beanstalk, AWS automatically creates:
EC2 Instances: Your app runs on these virtual machines.
Autoscaling Group: Adds or removes instances based on load.
Security Groups: Controls what traffic can reach your app.
Host Manager: A monitoring agent that handles logs, patches, and health checks on each instance.
Elastic Beanstalk Environment: A named environment with a public URL and CNAME, where your app lives.
Worker Environment
When web requests take too long to process, performance suffers. Elastic Beanstalk creates a background process that handles requests to avoid overloading the server. Worker Environments, a separate set of compute resources, processes longer-running tasks to ensure the resources serving the website can continue to respond quickly.
What is ECS?
If Elastic Beanstalk feels too limiting, but managing Kubernetes (via EKS) feels like overkill, Amazon ECS offers a strong middle ground. It’s a fully managed container orchestration service that lets you deploy and run Docker containers at scale while staying in control of the infrastructure.
ECS works natively with other AWS services like EC2, Elastic Load Balancing, and S3. You choose how much infrastructure to manage: run containers on EC2 instances you control, or offload that to AWS Fargate (more on that shortly).
ECS Architecture
The main components of ECS are:
Container Image: Your app, pre-packaged with OS, dependencies, and configs. Store it in Amazon Elastic Container Registry (ECR) or use external registries.
Task Definition: A JSON blueprint that defines which container images to run, how much CPU/memory to allocate, which ports to expose, and what IAM roles to apply.
Cluster: A logical group of EC2 instances (or Fargate resources) where your containers run.
Container Agent: An agent that runs on each EC2 instance in the cluster. It reports status and receives instructions from ECS.
Scheduler: Places tasks onto available infrastructure, based on your resource needs and scaling rules.
Working of ECS
When you deploy a task, ECS places it on an EC2 instance (or a Fargate-managed resource) inside a cluster. This way, you can:
Important: ECS gives you more granular control than Beanstalk. You define your container behavior and infrastructure settings but AWS still handles orchestration, networking, and scaling logic.
What is Fargate?
If you want to run containers on AWS without managing EC2 instances, autoscaling groups, or server clusters, AWS Fargate is your go-to option.
Fargate is a serverless compute engine for containers. It works with both Amazon ECS and EKS (Kubernetes). This way, you can deploy Docker containers without provisioning or managing infrastructure.
Fargate Architecture
Fargate’s architecture consists of three major components:
Task Definitions: JSON templates that describe what containers to run, how much CPU/memory to allocate, and which IAM roles or environment variables to apply.
Tasks: Individual running instances of a task definition. You tell Fargate how many to run, then it handles the infrastructure at the backend.
Clusters: A logical grouping for your tasks. Fargate manages the actual compute so there are no EC2 instances to configure or scale.
What You Get With Fargate
Here’s what you get with Fargate:
An easy, scalable, and reliable service
No server management required
No time spent on capacity planning
Scale seamlessly with no downtime
Pay-as-you-go pricing model
A low latency service, making it ideal for data processing applications
Integration with Amazon ECS, making it easier for companies to use both services in tandem
Comparing AWS Compute Services: Which One Fits?
AWS gives you remarkable flexibility when it comes to running containers and deploying applications.
But with that flexibility comes a new challenge:
Choosing the right service for the job.
From simple web apps to complex microservices, there’s no one-size-fits-all solution. Each service strikes a different balance between control, simplicity, scalability, and portability.
Elastic Beanstalk vs. ECS: Infrastructure Abstraction Versus Container Orchestration
When evaluating Elastic Beanstalk vs. ECS, the primary difference is the level of infrastructure abstraction and control over container orchestration.
Elastic Beanstalk is a managed Platform-as-a-Service built on top of Amazon EC2, Auto Scaling Groups, and Elastic Load Balancing. You deploy application code or a container image, and Beanstalk provisions the infrastructure and manages instance replacement, scaling policies, and rolling deployments.
It is appropriate for traditional web applications, single-container workloads, and organizations that do not want to manage orchestration primitives.
Beanstalk is often chosen by smaller organizations or early-stage projects that want to deploy quickly without investing in container orchestration.
Amazon ECS (Elastic Container Service) is a container orchestration service. It helps you define task definitions, configure CPU and memory reservations, assign task-level IAM roles, and control networking modes such as awsvpc.
ECS works best with microservices architectures, multi-container applications, and systems that require controlled deployment strategies such as blue/green or canary releases.
ECS also integrates naturally with container build pipelines and automated CI/CD workflows. Therefore, it is a better fit for organizations operating containerized microservices at scale.
Note: For simple web apps and single-container deployments, Beanstalk gets you there fast. But if your architecture needs more customization or your environment spans multiple services, ECS is the better fit.
Elastic Beanstalk is well-suited for:
Monolithic applications
Applications that require minimal infrastructure customization
Companies without dedicated Site Reliability Engineering resources
Workloads requiring fine-grained scaling or task placement control
Amazon ECS is well-suited for:
Containerized microservices
Applications requiring task placement strategies such as bin packing or spreading
Integration with service meshes or advanced observability tooling
Systems requiring explicit scaling policies
Amazon ECS introduces additional operational complexity because you must define cluster capacity (if using the EC2 launch type), configure networking, and manage scaling thresholds.
PRO TIP: Beanstalk is best for teams prioritizing simplicity; ECS is better suited for teams that need more architectural control.
AWS ECS vs. Fargate: Container Orchestration vs. Container Compute
Many engineers treat AWS Fargate vs ECS as a binary comparison. ECS and Fargate are not competing services. In reality, Amazon ECS and AWS Fargate operate at different layers. Fargate is a compute option used by ECS. In practice, ECS can run containers either on EC2 instances or on Fargate.
Amazon ECS is the orchestration control plane.
AWS Fargate is a serverless compute engine for containers.
When you run ECS using the EC2 launch type, you provision and manage the instances in your cluster. When you run ECS using the Fargate launch type, AWS provisions the compute capacity automatically.
ECS on EC2 is well-suited for:
Long-running steady-state services
Cost-optimized production workloads with predictable utilization
Workloads that benefit from Reserved Instances or Spot Instances
Applications requiring host-level tuning
ECS on Fargate is well-suited for:
Workloads with unpredictable or burst-heavy traffic patterns
Companies that want to eliminate cluster capacity management
Stateless services
Environments where operational simplicity is prioritized over cost optimization
Fargate removes the need for capacity planning and instance lifecycle management. However, at sustained high utilization, ECS running on EC2 is often more cost-efficient.
Note: While Fargate minimizes operational overhead, it can be more expensive per workload than running ECS on EC2 at scale.
Elastic Beanstalk vs. Fargate
Elastic Beanstalk and AWS Fargate both reduce infrastructure management, but they operate at different layers of abstraction and assume different levels of architectural maturity.
Elastic Beanstalk is a managed Platform-as-a-Service built on top of Amazon EC2, Auto Scaling Groups, and Elastic Load Balancing. It abstracts server provisioning, health monitoring, rolling deployments, and scaling configuration. You deploy application code or a Docker image, and Beanstalk manages the environment lifecycle.
AWS Fargate is a serverless compute option for running containers without managing EC2 instances. You can use Fargate with Amazon ECS or Amazon EKS, depending on which orchestration system you choose.
In this setup, ECS or EKS handles container orchestration (scheduling, scaling, and service management), while Fargate provides the underlying compute capacity. This means you do not provision or manage servers—the containers run on infrastructure managed by AWS.
This means you define task definitions, networking, CPU and memory reservations, and scaling policies, while Fargate provisions the underlying compute capacity.
Elastic Beanstalk is appropriate when:
You are deploying a traditional web application or a single-container
You do not need direct control over container scheduling or task placement
You does not want to manage container orchestration primitives
The application architecture is relatively simple and does not require multi-service coordination
You prefer opinionated infrastructure defaults and standardized deployment patterns
It works well for:
Early-stage products
Internal tools and dashboards
Companies without dedicated infrastructure engineers
Elastic Beanstalk is not ideal when:
You need fine-grained control over container networking or IAM roles per task
You are running multiple microservices that require service discovery
You need advanced deployment strategies such as canary or blue/green at the container level
You require custom autoscaling logic beyond Beanstalk’s environment-level scaling
You want direct integration with container-native observability tooling
In distributed systems or microservices environments, Beanstalk can become restrictive because it abstracts away the orchestration layer.
Fargate is appropriate when:
Your workloads are containerized
You want to eliminate EC2 instance provisioning and cluster capacity planning
Traffic patterns are variable or burst-heavy
You require task-level IAM isolation
You want container orchestration without managing servers
It works well for:
Stateless microservices
API backends with unpredictable traffic
Event-driven container workloads
Organizations comfortable defining ECS task definitions but unwilling to manage EC2 clusters
Fargate simplifies operational overhead by removing instance lifecycle management, patching, and cluster autoscaling configuration.
Fargate is less suitable when:
You require operating system level customization
You need specialized instance types such as GPU-backed workloads
You run large steady-state workloads where EC2 Reserved Instances provide better cost efficiency
You need host-level access for debugging or system tuning
You require custom network drivers or advanced kernel-level configurations
Recommendation: Use Beanstalk if you want minimal configuration and don’t need orchestration-level control. But if you’re comfortable managing containers and want to eliminate server and cluster management entirely, go with Fargate.
lastic Kubernetes Service
Kubernetes (K8s) is the industry standard for container orchestration but it’s not simple. Setting up and maintaining clusters, managing networking, scaling workloads, and securing communication all add serious overhead.
But it does automate container orchestration tasks like:
Service Discovery: Kubernetes exposes containers to accept requests via Domain Name Service (DNS) or an IP address.
Load Balancing: When container resource demand is too high, Kubernetes routes requests to other available containers.
Storage Orchestration: As storage needs grow, K8s mount additional storage to handle the workload.
Self-Healing: If a container fails, Kubernetes can remove it from service and replace it with a new one.
Secrets Management: The tool stores and manages passwords, tokens, and SSH keys.
In short, Kubernetes is helpful but complex. And that’s why you should prefer Amazon Elastic Kubernetes Service (EKS).
EKS delivers full Kubernetes capability without any need for running your own control plane. It’s a managed Kubernetes service for large-scale, production-grade workloads that need complete flexibility and power.
EKS Architecture
The Amazon EKS architecture consists of:
Control Plane (Managed): EKS runs and maintains the Kubernetes control plane (API server, controller manager, scheduler) so you don’t have to.
Worker Nodes (Your Responsibility): You manage and secure the EC2 instances (or use Fargate) that run your application containers.
Kubelet and Kube-Proxy: These services run on worker nodes to handle pod communication and internal networking.
VPC Integration: EKS runs inside a Virtual Private Cloud (VPC) for secure, isolated network communication.
Elastic Compute Cloud
Elastic Compute Cloud (EC2) is the infrastructure layer for AWS compute. It gives you raw virtual machines which are customizable, but also fully your responsibility to configure, secure, and maintain.
Every higher-level service (like ECS, EKS, and even Elastic Beanstalk) runs on top of EC2. But EC2 by itself is where you go when you want total control over the instance, OS, storage, networking, and software stack.
EC2 Architecture
The EC2 architecture consists of the following components:
Amazon Machine Image (AMI): A snapshot of a computer’s state that can be replicated over and over so you can deploy identical virtual machines.
EC2 Location: A geographic area that contains the compute, storage, and networking resources. The list of available locations varies by AWS product line. For example, regions in North America include the US East Coast (us-east-1), US West Coast (us-west-1), Canada (ca-central-1), and Brazil (sa-east-1).
Availability Zones are separate locations within a region that are well networked and help provide enhanced reliability of services that span more than one availability zone.
Type of Storage EC2 Supports
There are two main types of storage that EC2 supports:
Elastic Block Storage
These are volumes that exist outside of the EC2 instance itself, allowing them to be attached to different instances easily. They persist beyond the lifecycle of the EC2 instance, but as far as the instance is concerned, it seems like a physically attached drive. You can attach more than one EBS volume to a single EC2 instance.
EC2 Instance Store
This is a storage volume physically connected to the EC2 instance. It is used as temporary storage so you cannot attach it to other instances. That’s why the data will also be erased when the instance stops, hibernates, or terminates.
Lambda
AWS Lambda is a serverless computing platform that runs code in response to events. It was one of the first major services that AWS introduced to let developers build applications without any installation or up-front configuration of virtual machines.
Working of Lambda
When a function is created, Lambda packages it into a new container and executes that container on an AWS cluster. AWS then allocates the necessary RAM and CPU capacity. Because Lambda is a managed service, developers don’t make configuration changes which save time on operational tasks.
Here’s why you may consider Lambda for your needs:
You don’t have to manage any servers or containers.
It automatically scales based on usage spikes or event volume.
It offers fine-grained billing (charged by the millisecond).
It has strong security and compliance (PCI, HIPAA, ISO 27001, and more).
It gives flexible triggers and integrations with S3, API Gateway, DynamoDB, and beyond.
Lambda Architecture
The Lambda architecture has three main components:
Trigger: An event kicks off the function. This could be an S3 file upload, an HTTP request via API Gateway, a new record in DynamoDB, or a scheduled task. Lambda listens for these events and launches your function when they occur.
Function: This is your code, written in Python, Node.js, Java, Go, or another supported language. Lambda runs each function in its own stateless container, in complete isolation. It automatically manages execution, concurrency, and scaling.
Destination: Once the function finishes, Lambda can route the output somewhere else like another Lambda function, an SQS queue, SNS topic, or EventBridge bus.
Packaging Function
You can package your function in one of two ways:
For functions under 10MB, use a .zip file and upload it via the Lambda console or CLI.
For larger or more complex deployments, use a container image (hosted in Amazon Elastic Container Registry).
When a function executes, the AWS container that runs it starts automatically. Once the code executes, the container shuts down after a few minutes. This functionality makes functions stateless, meaning they don’t retain any information about the request once it shuts down. One notable exception is the /tmp directory, the state of which is maintained until the container shuts down.
Use Cases For AWS Lambda
Despite its simplicity, Lambda is versatile and can handle a variety of tasks. Here are a few cases:
Processing Uploads
When the application uses S3 as the storage system, there’s no need to run a program on an EC2 instance to process objects. Instead, a Lambda event can watch for new files and either process them or pass them on to another Lambda function for further processing. The service can even pass S3 object keys from one Lambda function to another as part of a workflow. For example, the developer may want to create an object in one region and then move it to another.
Automated Backups and Batch Jobs
Scheduled tasks and jobs are a perfect fit for Lambda. For example, instead of keeping an EC2 instance running 24/7, Lambda can perform the backups at a specified time. The service could also be used to generate reports and execute batch jobs.
Real-Time Log Analysis
A Lambda function could evaluate log files as the application writes each event. In addition, it can search for events or log entries as they occur and send appropriate notifications.
Automated File Synchronization
Lambda can synchronize repositories with other remote locations. This way, you can use a Lambda function to schedule file synchronization without creating a separate server and process.
How EC2 Relates to ECS, Fargate, and Beanstalk
EC2, ECS, and Fargate are often compared as if they were equivalent services. However, they are not:
EC2 provides computer infrastructure in the form of virtual machines.
ECS provides container orchestration.
Fargate provides serverless computers for containers.
These services operate at different layers.
ECS does not replace EC2, and it cannot run without compute capacity. When you use ECS, it must run on either EC2 instances that you provision or on Fargate, where AWS provisions compute automatically. In other words, ECS always runs on top of infrastructure. The only question is whether you manage that infrastructure yourself or AWS does it for you.
ECS vs EC2
When you use EC2 directly, you are responsible for everything running on that instance. That includes installing container runtimes, configuring scaling policies, replacing failed instances, and coordinating deployments. You manage both the servers and the application lifecycle.
When you use ECS, the responsibility moves to the container layer. ECS schedules tasks, performs health checks, and maintains the desired number of running containers.
If you choose the EC2 launch type, you still manage instance capacity. ECS removes container orchestration overhead, but infrastructure ownership remains yours.
Fargate vs EC2
With EC2, you select instance families, optimize cost using Reserved or Spot capacity, and tune performance at the operating system level. You control how capacity is provisioned and how resources are allocated across workloads.
With Fargate, you define CPU and memory at the task level and AWS provides the compute automatically. You do not provision, patch, or scale instances.
This removes capacity planning and instance management, but it also removes the ability to customize or optimize infrastructure at the host level.
AWS Elastic Beanstalk vs EC2
Using EC2 directly requires you to build and operate the full deployment stack, including scaling policies, load balancers, and health monitoring.
Elastic Beanstalk automatically creates and manages the EC2 instances that run your application, along with the Auto Scaling Groups and load balancers required to operate it.
The underlying infrastructure is still EC2, but instance lifecycle management is abstracted. The difference is not in capability, but in how much operational control you retain.
Migrating from ECS to EKS
There are valid reasons to start with ECS and equally valid reasons to migrate away from it later. And while switching between services is possible, choosing the right one from the start helps avoid costly rework or team frustration later on.
ECS is AWS-native, tightly integrated with the AWS ecosystem, and proprietary. EKS, on the other hand, runs upstream Kubernetes, which gives you cloud-agnostic flexibility and access to a massive open-source ecosystem.
This switch often happens when teams outgrow ECS’s constraints or want to adopt a standardized orchestration model across multi-cloud or hybrid environments.
Suppose a team running microservices in ECS wants to support a future deployment on-prem or in another cloud. By moving to EKS, they retain Kubernetes portability while continuing to benefit from AWS’s managed infrastructure.
Here’s a simplified version of what that migration might look like:
Export your ECS cluster definition to an Amazon S3 bucket using the ecs-to-eks tool.
Create a new EKS cluster using the AWS CLI, passing the exported JSON as input.
Connect to the new EKS cluster using kubectl, and use a script to import your container definitions from S3.
Use the aws elbv2 and aws eks commands or AWS CloudFormation to scale and update your workloads.
Once your application is running successfully on EKS, you can retire your ECS cluster.
AWS Compute Decision Table: Beanstalk vs. ECS vs. Fargate
If you:
Use:
Want the fastest path to deployment with minimal setup
Elastic Beanstalk
Need fine-grained control over container behavior and scheduling
ECS
Want to run containers without touching infrastructure
Fargate
Need Kubernetes for portability or ecosystem tools
EKS
Need full control over servers, OS, and networking
EC2
Choose Your Path, Then Monitor It
Choosing between Elastic Beanstalk, ECS, and Fargate comes down to how much control you want and how much time your team can realistically spend managing infrastructure. Whether you’re launching fast with Beanstalk or going all-in on containers with ECS and Fargate, one thing stays the same: visibility matters.
LogicMonitor helps you monitor all three, so you can keep your AWS environments running smoothly without juggling five different dashboards.
Gain Full Visibility Across Your AWS Compute Stack
Monitor Elastic Beanstalk, ECS, and Fargate workloads in one platform with LogicMonitor.
1. How do I choose between EC2, ECS, and Lambda for running my application?
Choose EC2 when you need full control over the operating system, networking, and instance configuration. ECS is better suited for containerized applications where you want managed orchestration but still control how services are deployed and scaled. Lambda works best for event-driven workloads where functions run only when triggered and do not require long-running computation.
2. What’s the key difference in Elastic Beanstalk vs ECS vs Fargate?
The main difference is the level of infrastructure control. Elastic Beanstalk abstracts infrastructure and manages EC2 instances, load balancers, and scaling for you. ECS provides container orchestration and requires you to define task definitions, networking, and scaling policies. Fargate works with ECS (or EKS) to run containers without managing EC2 instances.
3. When should I use AWS Fargate instead of EC2 for container workloads?
Use Fargate when you want to run containers without provisioning or managing EC2 instances. When you compare EC2 vs Fargate, EC2 gives more infrastructure control and cost optimization options, while Fargate removes cluster capacity management. Fargate is often preferred for variable workloads.
4. How does ECS compare with Fargate for container deployments?
When it comes to Fargate vs ECS, the key distinction is orchestration versus compute. ECS manages container orchestration, including task scheduling and service scaling.
Fargate provides the compute capacity for those containers, removing the need to manage EC2 instances. In practice, ECS and Fargate are often used together rather than as direct alternatives.
5. What is the difference between running ECS on EC2 and ECS on Fargate?
When evaluating ECS Fargate vs EC2, the difference lies in infrastructure ownership. Running ECS on EC2 means you provision and scale the instances that make up the cluster. Running ECS on Fargate removes that responsibility because AWS automatically provides compute capacity for your containers.
6. How does Elastic Beanstalk compare with EKS for container deployments?
When we talk about Elastic Beanstalk vs. EKS, the difference comes down to abstraction versus flexibility. Elastic Beanstalk simplifies deployment by managing infrastructure automatically. Amazon EKS provides a managed Kubernetes control plane, giving you full Kubernetes functionality and ecosystem tooling but requiring more operational expertise.
7. How do AWS EKS, ECS, and Fargate fit together?
When we look at AWS EKS vs ECS vs Fargate, the main difference is the orchestration model. ECS is AWS’s native container orchestration service, while EKS runs Kubernetes. Fargate can be used as the compute layer for containers running in either ECS or EKS, eliminating the need to manage EC2 instances.
