What is Docker Swarm and How Does it Work?
Explore Docker Swarm, a leading container orchestration solution, for managing IT infrastructure. Understand its unique features, working principles, and benefits in deployment and scaling.
9–13 minutes
August 4, 2023
Managing your IT infrastructure—whether it’s servers, databases, or applications—can feel overwhelming. That’s where container orchestration comes in. Simplifying complex environments helps you save time and operate more efficiently.
In this article, we’ll explain exactly what is Docker Swarm, how it works, its key features, and why it’s a popular choice for container orchestration.
What is Docker Swarm?
Docker Swarm is a native container orchestration tool developed by Docker. It simplifies the management and scaling of containers across several machines, helping optimize distributed systems. A swarm is a cluster of Docker hosts that function together as a single machine.
You can use a swarm to automate the deployment, scaling, and orchestration of containers, giving you the ability to function together in single virtual machines—allowing for streamlined resource management and workload distribution. Docker Swarm works well with minimal resources, so it’s great for small- or medium-sized projects that don’t need the features of other solutions.
Docker Swarm also connects to Docker through its API and CLI. This means a swarm is compatible with other Docker tools, making it easy for developers already familiar with the Docker ecosystem.
Key takeaways
Docker Swarm is a container orchestration tool that manages Docker containers across multiple servers in a cluster.
A swarm manager oversees the activities of the cluster while nodes contribute resources to ensure scalability and reliability.
Docker Swarm provides features like load balancing, service discovery, and fault tolerance for containerized applications.
It is ideal for small- to medium-scale deployments where simplicity and ease of use are priorities.
How does Docker Swarm work?
Docker Swarm works by orchestrating containerized applications across a cluster of machines, helping you easily maintain distributed systems. Its architecture and features are designed to simplify container management while ensuring high availability and scalability.
Docker Swarm breaks each swarm into a few parts:
  • Nodes: The individual machines in a cluster, with manager nodes handling the overall management and worker nodes executing tasks directed by the manager.
  • Service and task distribution: Docker Swarm distributes tasks in a cluster to ensure an even workload distribution and handle resource optimization. Services are the applications on worker nodes (container hosts) that execute those tasks.
  • Load balancing: Docker Swarm includes built-in load balancing features that distribute incoming traffic across the running containers to ensure efficient resource use. The monitoring nodes watch worker health and reschedule tasks on healthy nodes to maintain availability.
  • Networking: Docker Swarm has an overlay network to facilitate communication between nodes without requiring external port exposure and includes service discovery to ensure nodes can automatically discover each other.
  • Monitoring and reporting: Docker Swarm includes monitoring and reporting tools that give real-time insight into a swarm’s health and notify you automatically to help diagnose and resolve problems quickly.
Docker Swarm architecture
Docker Swarm architecture is built on key components: Nodes, Services, Availability, Managers, and Tasks. These elements work together to enable efficient container orchestration, ensuring scalability, fault tolerance, and workload distribution across a cluster.
Key features of Docker Swarm
Docker Swarm has many powerful features that make it a great solution for container orchestration on operating systems like Linux. Here are some of the primary ones to consider:
Easy setup and configuration
You can easily set up, configure, and integrate with the API and CLI, meaning developers won’t need to worry about additional tools or configurations. Docker Swarm features declarative configuration to define the state of your application and system and ensure your cluster matches your needs.
Automatic load balancing
It automatically distributes your traffic to containers running in your containers. Developers don’t need to distribute traffic manually—Docker Swarm will handle this automatically based on their parameters to ensure optimal performance and resource usage.
Scalability
Docker Swarm offers flexible scalability to help you manage increasing and decreasing loads. It does this through horizontal scaling, where a Docker Swarm adds more nodes or increases the number of container instances as the workload changes. The declarative service model also makes it easy to add services to new nodes that perform as expected.
Fault tolerance
Swarm managers use a leader-election mechanism to ensure high availability. A new one is automatically elected to schedule tasks if the current leader fails. Task rescheduling mechanisms are also available in cases of worker node failure.
It uses TLS encryption by default to secure node communication, ensuring data privacy and integrity. It also enables the “secure by default” approach, enabling security features like TLS and role-based authentication.
Rolling updates
Docker Swarm supports rolling updates, which allow you to deploy changes incrementally. This reduces downtime and ensures your system remains operational during updates. It also provides for rollbacks, enabling you to revert to previous configurations in case of problems.
Monitoring and insights
Built-in tools help you monitor your environment’s health. Docker Swarm monitors the health of nodes (workers and managers) and identifies potential issues you need to resolve. You can also find performance metrics that help you track performance over time to ensure you have consistent resource usage and performance.
Benefits of using Docker Swarm
Docker Swarm’s many features make it an attractive option for developers—especially in medium- to small-scale environments. Its simplicity and Docker integration make it quick to start with and get going, so let’s look at how that will help your team:
  • Compared to more complex orchestration tools like Kubernetes, Docker Swarm is straightforward to learn and implement, making it accessible to teams of varying experience levels.
  • It is a Docker-native tool that integrates well with the rest of the Docker ecosystem, meaning developers can easily move to Docker Swarm from other Docker configurations without changing tools.
  • Built-in high availability through fault tolerance and load balancing allows you to maintain performance at all times.
  • Simple and lightweight, Docker Swarm works great for resource-constrained environments and has minimal overhead.
  • Docker Swarm’s flexibility means you can deploy it in both on-prem and single-cloud environments without requiring a complex multi-cloud configuration. It also offers scalability to accommodate growing workloads.
  • It improves developer productivity and enables rapid prototyping and test applications, leading to faster development cycles.
With Docker Swarm, managing containerized applications becomes seamless, scalable, and straightforward, especially for small- to medium-sized teams.
Limitations of Docker Swarm
Docker Swarm has a lot of features that make it worth using in small environments, but there are a few drawbacks to consider. Let’s look at a few of them:
  • Simple system for developers to use, but it struggles in more complex environments, like hybrid and multi-cloud environments, where advanced orchestration tools excel.
  • Limited integration with external tools and plugins, which may not suit teams relying heavily on third parties.
  • Declining popularity as Kubernetes has become the industry standard for Docker orchestration, which means there is less community involvement and support than with other tools.
  • Limited advanced features like advanced networking capabilities, service meshes, and automatic scaling adjustments.
Docker Swarm mode and services
Docker Swarm operates in Swarm Mode, a built-in feature that allows the clustering and orchestration of Docker nodes. Swarm Mode introduces the concept of services and tasks that enable fine-grained control over container deployment.
Tasks
A task represents an instance of a running container. In Swarm Mode, tasks are assigned to worker nodes and are managed by the swarm. Each task is immutable and will be rescheduled if the node fails.
Services
A service defines how tasks are distributed across nodes. There are two types of services in Docker Swarm:
  • Replicated services: You specify the number of task replicas, and the swarm manager ensures that the defined number of instances are running across the cluster.
  • Global services: A task runs on every available node. This is useful for monitoring, logging, or network-related tasks.
Modes in Swarm mode
  • Manager mode: Manager nodes make scheduling and orchestration decisions for the entire swarm. They also store cluster state and manage leader elections.
  • Worker mode: Worker nodes execute tasks assigned by the manager node and report back on their status.
Docker Swarm vs. other orchestration tools
Container orchestration is not limited to just one tool. While Docker Swarm offers a simple and integrated solution, other tools like Kubernetes and Apache Mesos have unique strengths.
Docker Swarm vs. Kubernetes
Docker Swarm and Kubernetes are two leading players in container orchestration. Docker Swarm, a tool designed explicitly for Docker, is renowned for its user-friendly interface and straightforwardness. It comes with built-in features for load balancing and enables quick and seamless container deployment.
In contrast, Google’s open-source platform Kubernetes is highly regarded for its ability to automate containerized applications’ deployment, scaling, and management. Kubernetes can handle complex environments and allows for a variety of workload options, but its complexity makes setup and administration extra challenging.
These platforms stand out because of their ease of use. With its learning process and easier installation, Docker Swarm proves to be a choice for individuals already familiar with Docker commands or those working on smaller- to medium-sized projects. In contrast, Kubernetes benefits from a larger community and extensive third-party integrations, increasing support and access to various user tools.
Docker Swarm vs. Apache Mesos
Docker Swarm and Apache Mesos are powerful tools for effectively managing containerized applications. They both possess unique capabilities and commendable features that set them apart.
Docker Swarm is a simple yet powerful tool for clustering and scheduling Docker containers. It integrates with Docker services and offers key features such as load balancing, secure networks, service discovery, and scaling capabilities.
Apache Mesos is a versatile cluster manager that efficiently manages Docker containers and various workloads. It provides unparalleled flexibility.
Regarding usability, Docker Swarm excels with its user-friendly interface and simplified learning process. Users can seamlessly transition without learning new commands or concepts using the same API as Docker. On the other hand, Apache Mesos provides greater control over resources but may entail more complexity regarding setup and management.
Both tools excel in terms of scalability and performance. However, Apache Mesos is the best choice for managing extensive clusters because its efficient design is explicitly tailored for large systems.
Docker Swarm makes container orchestration simple, reliable, and free from unnecessary complexity.
Use cases for Docker Swarm
Docker Swarm’s efficiency makes it an excellent choice for many use cases. Let’s look at a few examples of what you can do.
Small to medium projects
Docker Swarm is a lightweight orchestration tool, making it an excellent choice for small and medium projects. If your project doesn’t need the advanced scaling and features of a Kubernetes installation, Docker Swarm can get you up and running more quickly. This is also good if your project requires minimal hardware resources (for microservices, for example) since Docker Swarm runs with minimal resources.
Temporary clusters and repaid deployment
Being able to deploy Docker Swarm quickly makes it a great choice for managing temporary clusters (testing and DevOps environments, for example) and rapid deployment scenarios for things like events, campaigns, and short-term projects. Your team won’t need to worry about complex Kubernetes setups or long-term maintenance.
Simple deployments
Using Docker Swarm provides straightforward solutions for teams needing simple container orchestration and not using complex environments (like multi-cloud solutions). It has a short learning curve and simple configuring, meaning your team can deploy quickly (without too much of a learning curve).
Docker-focused projects
As a native tool in the Docker ecosystem, Docker Swarm allows your team to manage containerized applications using familiar tools and workflows. Using a swarm means your team has less to learn to integrate new systems into your workflow.
How to get started with Docker Swarm
Getting started with Docker Swarm is a straightforward process. Below is an overview of the key set-up steps and a few resources for effective management.
Setting up Docker Swarm
Follow these steps to get started:
  1. Initialize the swarm:
    Run the following command on the primary node to create your swarm:
    docker swarm init
  2. Add nodes to the swarm:
    Add nodes to the swarm as worker nodes:
    docker swarm join  –token <TOKEN> / <MANAGER_IP>:2377
  3. Verify the cluster
    Ensure proper setup by verifying your cluster:
    docker node ls
Once set up, you can begin deploying services:
  1. Create a service:
    docker service create —name new-service —replicas 3 nginx
  2. Manage your service:
    Scale your service and inspect its details
    docker service scale new-service=5
    docker service inspect new-service
  3. Update your service:
    Perform rolling updates to avoid downtime
    docker service update —image nginx:latest new-service
Managing your Docker Swarm
Once you have set up Docker Swarm, you need guidelines to manage everything and keep it up and running. Use these tips to monitor your swarm cluster.
  • Keep an eye on the health of your nodes by using the inspect and ls commands to get the details.
  • Set up logging for troubleshooting tools like the Docker logging driver or other third-party solutions.
  • Leverage third-party monitoring tools to monitor the status of your cluster to ensure resource allocation looks good and everything stays performant.
  • Regularly back up your swarm configuration to safeguard against failure.
  • Use constraints and placement preferences to assign tasks to certain nodes for resource optimization, for example:
    docker service create –constraint ‘node.labels.type==high-memory’ –name memory-intensive-service nginx
For more information, check out the official resources from Docker:
  • Docker Swarm documentation
  • Docker CLI command reference
Docker Swarm offers a straightforward and efficient solution for container orchestration, making it an excellent choice for small- to medium-sized projects. It integrates into the Docker ecosystem, has built-in security, and offers essential features like load balancing to build a reliable foundation for containerized applications. Start building your cluster today to see the advantages of streamlined container management.
Are you looking for a solution to help monitor your containers? Read about our container monitoring to learn more.
How does Docker Swarm handle load balancing?
Docker Swarm automatically distributes incoming traffic across containers in a service. This helps maintain even resource use and keeps applications responsive without manual configuration.
When is Docker Swarm a better choice than Kubernetes?
Docker Swarm is a good choice for small- to medium-sized projects or teams that want simpler setup and management. It’s ideal when you need fast deployment without the complexity of Kubernetes.
How does Docker Swarm provide high availability?
Docker Swarm uses leader election and task rescheduling to maintain availability. If a manager or worker node fails, it automatically promotes a new leader or moves tasks to healthy nodes.
What security features are built into Docker Swarm?
Docker Swarm uses TLS encryption by default for secure node communication. It also supports role-based authentication to control access within the cluster.
Can Docker Swarm perform rolling updates without downtime?
Yes. Docker Swarm supports rolling updates that let you update services gradually. If issues arise, you can roll back to the previous version to keep applications stable.
How do replicated and global services differ in Docker Swarm?
Replicated services run a set number of container instances across the cluster. Global services run one container instance on every available node, which is useful for tasks like monitoring or logging.
Blog Synthetic Monitoring
September 14, 2026
September 14, 2026
Blog Observability
September 14, 2026
