Fortinet FortiManager Monitoring
Last updated - 23 July, 2025
Overview
LogicMonitor offers out-of-the-box monitoring for the Fortinet FortiManager device. Our monitoring suite uses SNMP to query FortiManager for a variety of health and performance metrics.
Setup Requirements
Add Resource Into Monitoring
Add your FortiManager host into monitoring. For more information on adding resources into monitoring, see Adding Devices.
Enable SNMP
SNMP must be configured on the FortiManager host in order for the DataSources to apply.
SNMP Credentials
LogicMonitor must provide the appropriate credentials in order to successfully access the FortiManager device via SNMP. For instructions on how to set the appropriate credentials as properties on the resource within LogicMonitor, see Defining Authentication Credentials.
Import LogicModules
From the LogicMonitor repository, import all Fortinet FortiManager LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, ensure you have the most recent versions.
Once the LogicModules are imported (assuming all previous setup requirements have been met), the suite of FortiManager DataSources will automatically begin collecting data.
LogicMonitor's package for Fortinet FortiManager consists of the following LogicModules. For full coverage, please ensure that all of these LogicModules are imported into your LogicMonitor platform.
| Display Name | Type | Description |
| FortiManager: Voltage Sensors | DataSource | Monitors the FortiManager voltage sensor operating state and value. |
| FortiManager: Temperature Sensors | DataSource | Monitors the FortiManager temperature sensor operating state and value. |
| FortiManager: RAID Info | DataSource | Monitors the RAID storage size, operating state and level. |
| FortiManager: RAID Disks | DataSource | Monitors RAID disk size and operating state. |
| FortiManager: Power Sensors | DataSource | Monitors the FortiManager power sensor operating state. |
| FortiManager: IP Sessions | DataSource | Monitors FortiManager IP sessions. |
| FortiManager: High Availability | DataSource | Monitors FortiManager high availability mode and number of peers. |
| FortiManager: HA Peers | DataSource | Monitors FortiManager high availability peer operating state. |
| FortiManager: Global Statistics | DataSource | Monitors FortiManager global performance statistics. |
| FortiManager: Fan Sensors | DataSource | Monitors the FortiManager fan sensor operating state and value. |
| FortiManager: Devices | DataSource | Monitors devices associated with the FortiManager. |
| FortiManager: Administrative Domains | DataSource | Monitors individual administrative domain states. |
When setting static datapoint thresholds on the various metrics tracked by this package's DataSources, LogicMonitor follows the technology owner's best practice KPI recommendations. If necessary, we encourage you to adjust these predefined thresholds to meet the unique needs of your environment. For more information on tuning datapoint thresholds, see Tuning Static Thresholds for Datapoints.
