Kemp LoadMaster Load Balancers
Last updated - 23 July, 2025
In this article
So long as snmp is accessible from the collector device, monitoring of Loadmasters is automatic, with the following caveats:
- LoadMasters do not run a full ntp process, so ntp monitoring is not possible. You should disable the ntp health check by clearing the enable box on that datasource.
- LoadMasters also do not respond to standard TCP monitoring, so that should be disabled as well.
