HPE 3PAR Monitoring
Last updated - 23 July, 2025
LogicMonitor’s monitoring suite for the HP 3PAR storage platform uses SSH to query the 3PAR appliance for a wide variety of health and performance metrics.
Compatibility
As of June 2022, LogicMonitor’s HP 3PAR package is known to be compatible with:
- Version 3.3.1 and up
As HP releases newer versions of 3PAR, LogicMonitor will test and extend coverage as necessary.
Setup Requirements
Add Resources into Monitoring
Add your 3PAR hosts into monitoring. For more information on adding resources into monitoring, see Adding Devices.
Obtain Credentials
LogicMonitor must provide the appropriate credentials needed to access the 3PAR resource’s data. 3PAR LogicModules use SSH to poll the array for performance data.
Important: To enable 3PAR monitoring you’ll need to first create an SSH administrative account on your 3PAR system with read-only privileges.
The following custom properties must be set on the 3PAR resource within LogicMonitor. For more information on setting properties, see Resource and Instance Properties.
| Property | Value |
| ssh.user | SSH username |
| ssh.pass | SSH password |
| system.categories | Add “3PAR-SSH” to system.categories.  Note: You must do this manually.  |
Import LogicModules
From the LogicMonitor public repository, import all HP 3PAR LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, make sure that you have the most recent versions. Once the LogicModules are imported, data collection will automatically commence.
Troubleshooting
The modules in this package are designed with a debug mode embedded in the data collection scripts. If issues occur, turn on debug mode by setting the variable debug to “true” to get more information in the output when testing the script in the Collector Debug Facility. For more information on testing scripts in the Collector Debug Facility, see Script Troubleshooting.
LogicMonitor’s package for HP 3PAR consists of the following LogicModules. For full coverage, make sure that all of these LogicModules are imported into your LogicMonitor platform.
| Display Name | Type | Description |
| 3PAR Controllers | DataSource | Statistics for 3PAR Controllers (nodes), including CPU and Cache metrics. |
| 3PAR CPG | DataSource | HP 3PAR Common Provisioning Group statistics for Virtual Volumes, Thinly Provisioned Virtual Volumes, and Thin Deduplicated Virtual Volumes. |
| 3PAR Disks | DataSource | Collects statistics for 3PAR disks or PD’s (physical disks). |
| 3PAR iSCSI | DataSource | iSCSI Network Statistics via SSH. |
| 3PAR Hardware Health | DataSource | Health status of various HP 3PAR hardware components. |
| 3PAR Ports | DataSource | Gathers data for 3PAR ports over ssh. |
| 3PAR VLUNs by Volume | DataSource | Summarizes VLUN statistics by volume. |
| 3PAR VLUNs by Host | DataSource | Summarizes VLUN statistics by host. |
| 3PAR Volumes | DataSource | Monitors HP 3PAR volume performance and utilization over SSH. |
