Cisco Intersight Monitoring
Last updated - 23 July, 2025
Overview
LogicMonitor offers built-in monitoring coverage for Cisco Intersight and, along with it, additional Cisco HyperFlex monitoring. Specifically, the Cisco Intersight monitoring package focuses on alarms, security advisories, and licenses, while also offering insight into the unique features for HyperFlex clusters (such as capacity runway estimation) that Intersight enables.
Cisco Intersight’s REST API is used extensively by this package. For more information on this API, refer to Cisco Intersight RESTful API.
Compatibility
As of August 2020, LogicMonitor’s Cisco Intersight package is known to be compatible with:
- Version 1 of the Intersight REST API
Setup Requirements
Satisfy Dependencies
- Requires LogicMonitor Collector version 28.606 or higher as this monitoring package harnesses modern authentication protocols included in this version.
 - The LogicMonitor Collector must be allowed to access https://{ACCOUNTID}.intersight.com.
 - Cisco Intersight must be running under an Essentials tier license or greater.
Add Resources Into Monitoring
Add an Intersight host into monitoring. Since this is a service and there is no physical resource to add into monitoring, you’ll need to manually create a new resource. Name your resource using the URL of the Intersight service (for example, https://{ACCOUNTID}.intersight.com). For more information on manually adding resources into monitoring, see Adding Devices.
Obtain Credentials
LogicMonitor must provide the appropriate credentials in order to successfully access the Intersight API’s data. These credentials must belong to an Essentials or higher licensed Intersight portal and consist of API key data.
An API key must be created and downloaded from https://intersight.com/an/settings/api-keys/. This API key ID (and secret) must then be entered as properties on the resource in LogicMonitor, as discussed in the next section.
The following custom properties must be set on the Cisco ISE resource within LogicMonitor. You have the option of providing the API key secret via a reference to a file or as text, depending on your security requirements.
For more information on setting properties on resources in LogicMonitor, see Resource and Instance Properties.
| Property | Value |
| cisco.intersight.account.id | The account ID that is available from the Settings|Account Details page within the Intersight UI. |
| cisco.intersight.key.id | The API key ID obtained in the above section. |
| cisco.intersight.secret.location | The location of the API key file on disk (for example ../keys/intersight.txt). This property is not required if the cisco.intersight.secret.key property is set. |
| cisco.intersight.secret.key | The full text contents of the exported API key file. This property is not required if the cisco.intersight.secret.location property is set. |
| system.categories | CiscoIntersight (this value should be automatically added by the addCategory_CiscoIntersight PropertySource, but can be manually added if necessary). |
Import LogicModules
From the LogicMonitor public repository, import all Cisco Intersight LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, ensure you have the most recent versions.
Once the LogicModules are imported (assuming all previous setup requirements have been met), data collection will automatically commence.
Considerations/Warnings
Expiration of the Intersight Essentials license will prevent API access to report on further issues—including issues related to license expirations. The Intersight package warns of expiration (14 days and 7 days in advance), but once the license expires, LogicMonitor is limited on what it can offer in terms of automated diagnostics.
Troubleshooting
Consistent HTTP failures during Active Discovery or data collection, which can be seen using the Test Script buttons that are available in the DataSource definition, usually hint at a firewall or DNS issue. Try and confirm that the Collector assigned to the Intersight resource can access the Intersight portal for your account before contacting support.
LogicMonitor’s package for Cisco Intersight consists of the following LogicModules. For full coverage, ensure that all of these LogicModules are imported into your LogicMonitor platform.
| Display Name | Type | Description |
| addCategory_CiscoIntersight | PropertySource | Identifies if the resource is a Cisco Intersight resource and assigns the value of “CiscoIntersight” to the system.categories property. |
| Cisco Intersight Licenses | DataSource | License information and expiry times for Cisco Intersight. |
| Cisco Intersight Hyperflex Clusters | DataSource | Cluster information for HyperFlex on Cisco Intersight. Includes Intersight metrics like capacity runway. |
| Cisco Intersight Hyperflex Alarms | Eventsource | Returns HyperFlex alarms for Cisco Intersight. |
| Cisco Intersight Security Advisories | Eventsource | Returns all security adversities for Cisco Intersight. |
