Dell SC Monitoring
Last updated - 23 July, 2025
Overview
Dell SC is a storage system branded as Dell Storage Center or Dell EMC Storage Center. LogicMonitor offers out-of-the-box monitoring for Dell SC based systems, allowing you to monitor various metrics for the storage devices including fan RPM, fan status, temperature, disk status, health status, global object count statistics, and more.
Compatibility
As of May 2020, LogicMonitor’s package for Dell SC is compatible with the following Dell SC based systems and supports the following models:
- Dell Compellent (SC4020, series 40)
- Dell Storage (SC5020, SC5020F, SC7020, SC7020F, SC8000, SC9000, SCv300, SCv360, SCv2000, SCv2020, SCv2080, SCv3000, SCv3020, SCv3200).
Note: As discussed in the Migration from Dell Compellent to Dell SC LogicModules section of this support article, you must use the Dell SC package (and not our Dell Compellent LogicModules) to monitor any of the above-listed systems. However, you should (continue to) use our Dell Compellent LogicModules to monitor any Compellent systems not listed above.
Setup Requirements
Add Resource Into Monitoring
Add your Dell SC devices into monitoring. The device’s IP or hostname must be entered into the IP Address/DNS name field or monitoring will fail. For more information on adding resources into monitoring, see Adding Devices.
Enable SNMP
SNMP must be configured on the Dell SC host in order for the DataSources to successfully collect data. For more information on the SNMP values used, see Dell Storage Center Operating Systems (MIB).
Enter SNMP Credentials
LogicMonitor must provide the appropriate credentials in order to successfully access the Dell SC system via SNMP. For instructions on how to set the appropriate credentials as properties on the resource within LogicMonitor, see Defining Authentication Credentials.
Import LogicModules
From the LogicMonitor repository, import all Dell SC LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, ensure you have the most recent versions.
Once the LogicModules are imported (assuming all previous setup requirements have been met), the suite of Dell SC LogicModules will automatically begin collecting data.
The Dell SC monitoring package (all DataSource names in this package are prepended with “Dell_SC”) is intended to replace all Dell Compellent and Dell SC Compellent LogicModules (names are prepended with “Dell_Compellent” and “Dell_SC_Compellent” respectively) for monitoring of any of the above-listed systems.
The Dell SC monitoring package was added because, in recent hardware, it’s been discovered that the discovery and collection of important data such as temperature, fans, fan status, and other data has become unreliable as Dell transitions away from the older 1.3.6.1.4.1.16139 Compellent technologies OID to the newer 1.3.6.1.4.1.674.11000.2000.500.1 Dell Storage Center OID. The Dell SC package uses only the latter OID for discovery and collection.
You may see duplicate alerts if you are monitoring compatible Dell SC devices with both the newer Dell SC DataSources and the older Dell (SC) Compellent DataSources. For this reason, we recommend that you disable any Dell Compellent DataSources after importing the new set of Dell SC DataSources and confirming that they are working as intended in your environment.
When a DataSource is disabled, it stops querying the host and generating alerts, but maintains all historical data. At some point in time, you may want to delete the DataSources altogether, but consider this move carefully as all historical data will be lost upon deletion. For more information on disabling DataSources, see Disabling Monitoring for a DataSource or Instance.
Note: The new Dell SC package does not work with older Compellent systems (see list of supported models in the Compatibility section of this support article) so if you would like to continue monitoring these older systems, do not disable the associated Compellent DataSources.
LogicMonitor’s package for Dell SC consists of the following LogicModules. For full coverage, please ensure that all of these LogicModules are imported into your LogicMonitor platform.
| Name | Type | Description |
| addCategory_Dell_SC | PropertySource | Identifies Dell SC hosts and applies a system category of “Dell_SC” |
| Dell_SC_Cache | DataSource | Show the status of cache and the cache battery for Dell SC systems |
| Dell_SC_Controller_Leader_Status | DataSource | Monitors Dell SC controller status and leader status |
| Dell_SC_Controller_Voltage | DataSource | Returns status for power supply voltage on Dell SC systems |
| Dell_SC_Disk_Info | DataSource | Gathers disk info on port type, size, status, and health from Dell SC systems |
| Dell_SC_DiskFolder_Space | DataSource | Shows disk size and folder space info for Dell SC Systems |
| Dell_SC_DiskFolder_Status | DataSource | Monitors DiskFolder Status on Dell SC systems |
| Dell_SC_Enclosure_Status | DataSource | Monitors the status of the enclosure on Dell SC systems |
| Dell_SC_Fans | DataSource | Monitors fan RPMs and status on Dell SC systems |
| Dell_SC_IOModules | DataSource | Monitors io module status in Dell SC systems |
| Dell_SC_Object_Count | DataSource | Monitors server, disk, volume, and replay counts on Dell SC devices |
| Dell_SC_PathConnection_Status | DataSource | Monitors Dell SC server status, connectivity status, and path count |
| Dell_SC_Power | DataSource | Monitors status for power supplies on Dell SC systems |
| Dell_SC_System_Status | DataSource | Monitors the system status for Dell SC Systems |
| Dell_SC_Temperature | DataSource | Monitors temperature and temperature status for Dell SC systems |
| Dell_SC_Volumes | DataSource | Monitors volume status information for Dell SC systems |
