Overview
LogicMonitor offers out-of-the-box monitoring for the Fortinet FortiWeb web application firewall (WAF). Our monitoring suite uses SNMP to query the FortiWeb firewall for a variety of health and performance metrics. ​
Setup Requirements
Add Resource Into Monitoring
Add your FortiWeb host into monitoring. For more information on adding resources into monitoring, see Adding Devices.
Enable SNMP
SNMP must be configured on the FortiWeb host in order for the DataSources to apply.
SNMP Credentials
LogicMonitor must provide the appropriate credentials in order to successfully access the FortiWeb resource via SNMP. For instructions on how to set the appropriate credentials as properties on the resource within LogicMonitor, see Defining Authentication Credentials.
Import LogicModules
From the LogicMonitor repository, import all Fortinet FortiWeb LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, ensure you have the most recent versions.
Once the LogicModules are imported (assuming all previous setup requirements have been met), the suite of FortiWeb DataSources will automatically begin collecting data.
LogicMonitor’s package for Fortinet FortiWeb consists of the following LogicModules. For full coverage, please ensure that all of these LogicModules are imported into your LogicMonitor platform.
Display Name Type Description
FortiWeb: Global Statistics DataSource Monitors FortiWeb global performance metrics.
FortiWeb: CPU Usage DataSource Monitors FortiWeb cpu usage metrics.
