Fortinet FortiWLC Monitoring
Last updated - 23 July, 2025
Overview
LogicMonitor offers out-of-the-box monitoring for the Fortinet Wireless Controller (FortiWLC). Our monitoring suite uses SNMP to query FortiWLC for a variety of health and performance metrics.
Setup Requirements
Add Resource Into Monitoring
Add your FortiWLC host into monitoring. For more information on adding resources into monitoring, see Adding Devices.
Enable SNMP
SNMP must be configured on the FortiWLC host in order for the DataSources to apply.
SNMP Credentials
LogicMonitor must provide the appropriate credentials in order to successfully access the FortiWLC device via SNMP. For instructions on how to set the appropriate credentials as properties on the resource within LogicMonitor, see Defining Authentication Credentials.
Import LogicModules
From the LogicMonitor repository, import all Fortinet FortiWLC LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, ensure you have the most recent versions.
Once the LogicModules are imported (assuming all previous setup requirements have been met), the suite of FortiWLC DataSources will automatically begin collecting data.
LogicMonitor's package for Fortinet FortiWLC consists of the following LogicModules. For full coverage, please ensure that all of these LogicModules are imported into your LogicMonitor platform.
| Display Name | Type | Description |
| FortiWLC: Interfaces | DataSource | Monitors FortiWLC interface metrics such as throughput, packet transmission and errors. |
| FortiWLC: Global Statistics | DataSource | Monitors FortiWLC controller global stats. |
| FortiWLC: ESS Statistics | DataSource | Monitors FortiWLC ESS (Extended Service Set) performance stats. |
| FortiWLC: Access Points Performance Stats | DataSource | Monitors Meru access points status and performance stats. |
| FortiWLC: Access Points Operating Status | DataSource | Monitors Meru access points status and performance stats. |
When setting static datapoint thresholds on the various metrics tracked by this package's DataSources, LogicMonitor follows the technology owner's best practice KPI recommendations. If necessary, we encourage you to adjust these predefined thresholds to meet the unique needs of your environment. For more information on tuning datapoint thresholds, see Tuning Static Thresholds for Datapoints.
