Network Traffic Flow Monitoring
Last updated - 25 June, 2026
Overview
Network traffic flow (NetFlow) monitoring collects IP network traffic as it enters or exits an interface. LogicMonitor Collectors receive and analyze data from resources that support common flow export protocols. LogicMonitor can report on the following statistics:
- Top talkers
- Top source/destination endpoints
- Top flows
- Top ports
- Top applications
- Quality of service (QoS)
The following network flow export protocols are supported:
- NetFlow versions 5, 7, and 9
- Flexible NetFlow
- IPFIX
- sFlow versions 1, 3, and 5.
Note: sFlow version 5 requires a LogicMonitor Collector version 29.105 or higher.
- JFlow version 5
- NBAR2
Note: The ability to collect NBAR2 data is limited to LogicMonitor Enterprise accounts and requires a LogicMonitor Collector version 29.101 or higher. If you intend to collect NBAR2 data, you must set the netflow.nbar.enable property on the LogicMonitor Collector to TRUE. For more information, see the “Configuring the LogicMonitor Collector for Network Traffic Flow Monitoring” section of this article.
Best Practices
- Ensure your Collector has the capacity to monitor network traffic flows. For more information, see Collector Capacity.
- Minimize network hops between the LogicMonitor Collector and the resource. Network flow records are sent using the UDP communications protocol. Because UDP delivery is not guaranteed, it is recommended that you ensure the LogicMonitor Collector has the fewest network hops possible to the resource in order to minimize potential flow disruption due to network congestion or complexity.
- Synchronize clocks between the transmitting resource and the resource that is hosting the LogicMonitor Collector. If resources are located in different time zones, it is recommended that you use UTC or standardize on a single time zone.
- Eliminate port conflict. The host that is collecting network traffic data must not have any other network traffic analyzer listening on the same port. This can potentially cause contention and prevent traffic data from displaying in LogicMonitor.
By default, Collectors install with standard network traffic flow monitoring settings that do not require modification in most cases. However, you can override default settings to meet the unique needs of your monitoring environment.
| Name | Type | Default | Details |
| netflow.enable | Boolean | TRUE | If TRUE, the network flow module is enabled on Collector. |
| netflow.ports | Integer | 2055 | The UDP listening port for network flow protocol data. The UDP port on the resource that is sending the flow data must match the UDP port specified here. Multiple ports can be configured here if you need to support multiple protocols on multiple ports (for example, netflow.ports=2055,4739).
| netflow.sflow.ports | Integer | 6343 | The UDP listening port for sFlow protocol data. |
| netflow.datadir | String | netflow | The path of the HSQL database. |
| netflow.datadir.maxSizeInMB | Integer | 10240 | The maximum size (in megabytes) of the network flow data directory. |
| netflow.log.maxNumPerMinute | Integer | 5 | The maximum log count allowed to be written during one minute of network flow monitoring. |
| netflow.netflow9.templateLife | Integer | 720 | The expiration time (in hours) of NetFlow version 9 template. |
| netflow.topFlowSamples | Integer | 1000 | The maximum sample number of top flows. Allowed range is from 100 to 2000. |
| netflow.ignoreTimestampValidate | Boolean | FALSE | If TRUE, the Collector ignores network flow resource time information. Currently, the only known resources that necessitate overriding the default FALSE value are SonicWalls. |
| netflow.nbar.enable | Boolean | FALSE | If TRUE, the Collector begins parsing the applicationID and ApplicationType. LogicMonitor Enterprise and Collector version 29.101 or higher are required. |
| netflow.ipv6.enabled | Boolean | TRUE | If FALSE, the Collector will ignore flows from with IPv6 addresses |
| netflow.log.largeBytesOrPackets | Integer | 1073741824 | Logs flows in Audit Logs with packets or bytes larger than the integer specified |
Enabling Network Traffic Monitoring in LogicMonitor
Network traffic monitoring is enabled on a per-resource basis.
To enable network traffic monitoring, do the following:
- In LogicMonitor, navigate to the Resources page and locate the resource you want to enable network traffic monitoring for.
- With the resource selected, select the Manage button.
- From the Manage page, toggle the Enable Network Flow Analysis switch.
- Select the Collector that will be used to receive exported network flow data. Network flow collection duties cannot be assigned to an Auto-Balanced Collector Group.
- Select Save.
Note: If your network flow exporter is sending data from an IP address that is not the same as the monitored IP address of the resource, customize the netflow.allowips property on the resource with the IP addresses from which network flow originates. This property accepts either a single IP or a comma-separated list as its value. For more information, see Resource and Instance Properties.
Enabling Network Traffic Flow Monitoring on a Resource
In addition to enabling network traffic monitoring in LogicMonitor, you must also enable it on your resource. Configurations vary depending on the resource, vendor, network topology, and protocol you are using. It is recommended that you review manufacturer guidelines for your specific resources.
The following resource configurations are applicable to all protocols:
- Network flow monitoring must be enabled per interface.
- A version number must be specified.
- A source interface for the flow exporter must be specified.
- The UDP port configured for the exporter must match the port specified in the Collector’s agent.conf file. For more information, see the “Configuring the LogicMonitor Collector for Network Traffic Flow Monitoring” section of this article.
- The clock on the resources should be synchronized with the clock on the Collector host.
- The IP address of the destination (the LogicMonitor Collector) must be specified.
- (NetFlow version 9 only) Additional template configuration options must be set.
- (sFlow only) Packet data must be provided in the
enterprise=0andformat=1packet configuration as described in RFC2233. In addition, sFlow uses port 6343. - (NBAR2) The option application-table and option application-attributes must be enabled on the exporter configuration of the resource. For more information, see Cisco’s NBAR Configuration Guide.
Sample Configurations
The following are sample NetFlow version 9 resource configurations. Because these sample configurations have the potential to become outdated as Cisco makes updates, refer to Cisco’s NetFlow Configuration and Flexible NetFlow Configuration guides to ensure up-to-date information.
Cisco IOS 3745 router – NetFlow Version 9, Main Cache Export
Configure global settings: source interface, NetFlow version, target NetFlow Collector, and UDP port.
To begin, enter the following at the command line:
Router#conf t
Then, enter the configurations for the global settings:
Router(config)#ip flow-export source FastEthernet0/0
Router(config)#ip flow-export version 9
Router(config)#ip flow-export destination 10.0.0.10 2055
Configure global template settings: refresh-rate, timeout-rate, and options.
Router#conf t
Then, enter the configurations for the global template settings:
Router(config)#ip flow-export template refresh-rate 15
Router(config)#ip flow-export template timeout-rate 90
Router(config)#ip flow-export template options export-stats
Router(config)#ip flow-export template options refresh-rate 25
Router(config)#ip flow-export template options timeout-rate 120
Configure the interface settings: enable route-cache flow
Router#conf t
Router(config)#interface fa0/0
Router(config-if)#ip route-cache flow
Note (Palo Alto users): There is a limited ability to customize the name of Palo Alto interfaces. According to Palo Alto, the interface name cannot be edited. However, you do have the ability to append a numeric suffix to the interface name for subinterfaces, aggregate interfaces, VLAN interfaces, loopback interfaces, and tunnel interfaces.
Note (for Barracuda users): Those using Barracuda NG Firewalls exporting IPFIX/NetFlow v9 will need to consult Barracuda documentation for proper configuration. Specifically, you will need to adjust the following settings: change “Byte Order” to “LittleEndian” and change the IPFIX template for Export to “Default without Barracuda fields”.
Required and Supported Fields for NetFlow Exports
| Field Type | Number | Description | Comments |
| PROTOCOL | 4 | IP protocol type | Mandatory |
| IPV4_SRC_ADDR | 8 | IPv4 source address | Mandatory for IPv4 addresses (if the Collector is IPv6 enabled and flows have IPv6 addresses, IPv6 source and destination fields (IPV6_SRC_ADDR and IPV6_DST_ADDR) should alternately be used) |
| IPV4_DST_ADDR | 12 | IPv4 destination address | |
| DIRECTION | 61 | Flow direction | Optional (if not provided, the default value of 0 will be used, which indicates ingress) |
| SRC_TOS | 5 | Type of Service byte setting when entering incoming interface | Optional |
| DST_TOS | 55 | Type of Service byte setting when exiting outgoing interface | Optional |
| TCP_FLAGS | 6 | Cumulative of all the TCP flags seen for this flow | Optional |
| LAST_SWITCHED_FT | 21 | System uptime at which the last packet of this flow was switched | Optional (if not provided, current epoch time will be used as the default value) |
| FIRST_SWITCHED_FT | 22 | System uptime at which the first packet of this flow was switched | Optional (if not provided, current epoch time minus 60 seconds will be used as the default value) |
| Multicast Group | |||
| IS-MULTICAST | 206 | The first bit of this octet is set to 1 if the Version field of the IP header has the value 4 and if the destination address field contains a reserved multicast address in the range from 224.0.0.0 to 239.255.255.255; otherwise, this bit is set to 0. The second and third bits of this octet are reserved for future use. | Optional |
| REPLICATION_FACTOR | 99 | Multicast replication factor | Optional |
| MUL_DST_PKTS | 19 | IP multicast outgoing packet counter with length N x 8 bits for packets associated with the IP Flow | Optional |
| MUL_DST_BYTES | 20 | IP multicast outgoing byte counter with length N x 8 bits for bytes associated with the IP Flow | Optional |
| Interface Group | |||
| INPUT_SNMP | 10 | SNMP ingress interface index | At least one of these fields must be present |
| OUTPUT_SNMP | 14 | SNMP egress interface index | |
| Bytes Group | |||
| IN_BYTES | 1 | Incoming counter with length N × 8 bits for number of bytes associated with an IP flow | At least one of these fields must be present |
| OUT_BYTES | 23 | Outgoing counter with length N x 8 bits for the number of bytes associated with an IP flow | |
| Source/Destination Port Groups | |||
| L4_SRC_PORT | 7 | TCP/UDP source port number | At least one of these fields must be present |
| L4_DST_PORT | 11 | TCP/UDP destination port number | |
| Packets Group | |||
| IN_PKTS | 2 | Incoming counter with length N x 8 bits for the number of packets associated with an IP flow | At least one of these fields must be present |
| OUT_PKTS | 24 | Outgoing counter with length N x 8 bits for the number of packets associated with an IP flow | |
| NBAR Group | |||
| APPLICATION DESCRIPTION | 94 | Description of the application | At least one of these fields must be present |
| APPLICATION NAME | 96 | Application name associated with a classification | |
| APPLICATION TAG | 95 | Eight bits of engine ID, followed by n bits of classification | Mandatory |
| APPLICATION GROUP | 12234/45002 | Groups applications that belong to the same networking application | At least one of these fields must be present |
| CATEGORY | 12232/45000 | Provides first-level categorization for each application | |
| ENCRYPTED | 290 | Specifies whether the application is an encrypted networking protocol | |
| P2P TECHNOLOGY | 288 | Specifies whether the application is based on peer-to-peer technology | |
| SUB-CATEGORY | 12233/45001 | Provides second-level categorization for each application | |
| TUNNEL TECHNOLOGY | 289 | Specifies whether the application tunnels the traffic of other protocols | |
| IPv6 Group | |||
| IPV6_SRC_ADDR | 27 | IPv6 source address | Mandatory for flows with IPv6 addresses |
| IPV6_DST_ADDR | 28 | IPv6 destination address | |
| IPV6_SRC_MASK | 29 | Length of the IPv6 source mask in contiguous bits | Optional |
| IPV6_DST_MASK | 30 | Length of the IPv6 destination mask in contiguous bits | Optional |
| IPV6_FLOW_LABEL | 31 | IPv6 flow label as per RFC 2460 definition | Optional |
| Sampling Group | |||
| FLOW_SAMPLER_ID | 48 | Identifier shown in “show flow-sampler” | Optional |
| FLOW_SAMPLER_MODE | 49 | The type of algorithm used for sampling data: 0x02 random sampling | Optional |
| SAMPLING_ALGORITHM | 35 | The type of algorithm used for sampled NetFlow: 0x01 Deterministic Sampling ,0x02 Random Sampling | Optional |
| FLOW_SAMPLER_RANDOM_INTERVAL | 50 | Packet interval at which to sample. Use in connection with FLOW_SAMPLER_MODE | Optional |
| SAMPLING_INTERVAL | 34 | Packet interval at which to sample | Optional |
| SAMPLER_NAME | 84 | Name of the flow samp | Optional |
| Extended Cisco ASA Device Group | |||
| NF_F_CONN_ID | 148 | An identifier of a unique flow for the resource | Optional |
| NF_F_FLOW_CREATE_TIME_MSEC | 152 | The time that the flow was created, which is included in extended flow-teardown events in which the flow-create event was not sent earlier. The flow duration can be determined with the event time for the flow-teardown and flow-create times. | Optional |
| NF_F_EVENT_TIME_MSEC | 323 | The time in which the event occurred, which comes from IPFIX. Use 324 for time in microseconds, and 325 for time in nanoseconds. Time has been counted as milliseconds since 0000 UTC January 1, 1970. | Optional |
| NF_F_FLOW_BYTES | 85 | Mandatory for Cisco ASA 9.0 | |
| NF_F_FW_EVENT_90 | 40005 | At least one of these fields must be present | |
| NF_F_FW_EVENT_91 | 233 | High-level event code. Values are as follows:
| NF_F_FWD_FLOW_DELTA_BYTES | 231 | The delta number of bytes from source to destination | Mandatory for Cisco ASA 9.1 |
| NF_F_REV_FLOW_DELTA_BYTES | 232 | The delta number of bytes from destination to source | Mandatory for Cisco ASA 9.1 |
| IPFIX/NetFlow Version 10 Group | |||
| flowStartSeconds | 150 | The absolute timestamp of the first packet of this flow | Optional |
| flowEndSeconds | 151 | The absolute timestamp of the last packet of this flow. | Optional |
| flowEndMilliseconds | 153 | The absolute timestamp of the last packet of this flow | Optional |
| systemInitTimeMilliseconds | 160 | The absolute timestamp of the last re-initialization of the IPFIX device | Optional |
Viewing Network Traffic Flow Data
Network traffic flow data is displayed on the Traffic tab on the Resources page for an enabled resource. For more information, see Viewing, Filtering and Reporting on Network Traffic Flow Data.
