Join us on April 3 to Level Up Your IT Universe with LogicMonitor's Latest Innovations!
Secure your spot
HPE 3PAR Monitoring
Last updated on 01 October, 2024
LogicMonitor’s monitoring suite for the HP 3PAR storage platform uses SSH to query the 3PAR appliance for a wide variety of health and performance metrics.
Compatibility
As of June 2022, LogicMonitor’s HP 3PAR package is known to be compatible with:
  • Version 3.3.1 and up
Setup Requirements
  • Import the LogicMonitor_Collector_Snippets DataSource to ensure that your collector supports the code in this monitoring suite, or update to EA Collector 32.100 or later.
Add Resources into Monitoring
Add your 3PAR hosts into monitoring. For more information on adding resources into monitoring, see Adding Devices.
Obtain Credentials
LogicMonitor must provide the appropriate credentials needed to access the 3PAR resource’s data. 3PAR LogicModules use SSH to poll the array for performance data.
Important: To enable 3PAR monitoring you’ll need to first create an SSH administrative account on your 3PAR system with read-only privileges.
The following custom properties must be set on the 3PAR resource within LogicMonitor. For more information on setting properties, see Resource and Instance Properties.
PropertyValue
ssh.userSSH username
ssh.passSSH password
system.categoriesAdd “3PAR-SSH” to system.categories.
Note: You must do this manually.
Import LogicModules
From the LogicMonitor public repository, import all HP 3PAR LogicModules, which are listed in the LogicModules in Package section of this support article. If these LogicModules are already present, make sure that you have the most recent versions. Once the LogicModules are imported, data collection will automatically commence.​
Troubleshooting
The modules in this package are designed with a debug mode embedded in the data collection scripts. If issues occur, turn on debug mode by setting the variable debug to “true” to get more information in the output when testing the script in the Collector Debug Facility. For more information on testing scripts in the Collector Debug Facility, see Script Troubleshooting.
LogicMonitor’s package for HP 3PAR consists of the following LogicModules. For full coverage, make sure that all of these LogicModules are imported into your LogicMonitor platform.
Display NameTypeDescription
3PAR ControllersDataSourceStatistics for 3PAR Controllers (nodes), including CPU and Cache metrics.
3PAR CPGDataSourceHP 3PAR Common Provisioning Group statistics for Virtual Volumes, Thinly Provisioned Virtual Volumes, and Thin Deduplicated Virtual Volumes.
3PAR DisksDataSourceCollects statistics for 3PAR disks or PD’s (physical disks).
3PAR iSCSIDataSourceiSCSI Network Statistics via SSH.
3PAR Hardware HealthDataSourceHealth status of various HP 3PAR hardware components.
3PAR PortsDataSourceGathers data for 3PAR ports over ssh.
3PAR VLUNs by VolumeDataSourceSummarizes VLUN statistics by volume.
3PAR VLUNs by HostDataSourceSummarizes VLUN statistics by host.
3PAR VolumesDataSourceMonitors HP 3PAR volume performance and utilization over SSH.
When setting static datapoint thresholds on the various metrics tracked by this package’s DataSources, LogicMonitor follows the technology owner’s best practice KPI recommendations. If necessary, we encourage you to adjust these predefined thresholds to meet the unique needs of your environment. For more information on tuning datapoint thresholds, see Tuning Static Thresholds for Datapoints.
In This Article
